주요 콘텐츠로 건너뛰기
InFocus LP540 Projector Speakers Replacement
필요한 것
  1. InFocus LP540 Projector Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 1개 InFocus LP540 Projector Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 2개 InFocus LP540 Projector Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 3개
    • Flip the projector right-side up and turn it so the backports face you.
    • Remove the 7mm metallic hex screws using the screwdriver.
    • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
  2. InFocus LP540 Projector Speakers Replacement: 2 단계, 이미지 2개 중 1개 InFocus LP540 Projector Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 77mm screws that are located nearest to the back panel ports using a T10 Torx screwdriver.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver.
    • Flip the projector back over.
    • Cautiously lift the main lid to avoid ripping the electrical strips.
  3. InFocus LP540 Projector Speakers Replacement: 3 단계, 이미지 2개 중 1개 InFocus LP540 Projector Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Unplug the speaker wire from the circuit board by squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
  4. InFocus LP540 Projector Speakers Replacement: 4 단계, 이미지 3개 중 1개 InFocus LP540 Projector Speakers Replacement: 4 단계, 이미지 3개 중 2개 InFocus LP540 Projector Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • Place the top shell of the projector down.
    • Remove the speaker wires from the white tabs.
    • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws.
    • Carefully lift the speakers to remove them.
결론
Reassembly: Close the speaker compartment and replace the light cover. Screw it back into place to secure all parts.
작성자
9다른 기여자 명과 함께
Jorge L Navarro
회원 가입일: 01/22/14
533 평판
안내서 5개를 작성함
Cal Poly, Team 13-17, Regan Winter 2014 Cal Poly, Team 13-17, Regan Winter 2014 회원
CPSU-REGAN-W14S13G17
6 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 700
