주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus Screenplay 4805 Light Tunnel Replacement
필요한 것
    1. InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: 1 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: 1 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: 1 단계, 이미지 3개 중 3개
      • Flip the projector on its back.
      • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
      • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
      댓글 쓰기
    2. InFocus Screenplay 4805 Light Tunnel Replacement: 2 단계, 이미지 2개 중 1개 InFocus Screenplay 4805 Light Tunnel Replacement: 2 단계, 이미지 2개 중 2개
      • Turn the projector, facing the back cable board towards you.
      • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
      • Gently take off back cable panel.
      댓글 쓰기
    3. InFocus Screenplay 4805 Light Tunnel Replacement: 3 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Light Tunnel Replacement: 3 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Light Tunnel Replacement: 3 단계, 이미지 3개 중 3개
      • Turn the projector so the front side with the lens is facing you.
      • Gently pry the both of the grey lens rings using the metal spudger.
      댓글 쓰기
    4. InFocus Screenplay 4805 Light Tunnel Replacement: 4 단계, 이미지 1개 중 1개
      • Now that the screws have been removed, proceed with the removal of the outer panel.
      • Gently remove the front lens panel.
      • Be forewarned, the panel will resist. Be careful not to break the lens.
      댓글 쓰기
    5. InFocus Screenplay 4805 Light Tunnel Replacement: 5 단계, 이미지 1개 중 1개
      • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
      • Rest the lid behind the projector so the insides are exposed and undamaged.
      댓글 쓰기
    1. InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: 6 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: 6 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: 6 단계, 이미지 3개 중 3개
      • With the lens facing you, remove the following screws:
      • Using the Phillips #1 screwdriver, remove the (3) three 1.25 cm gold screws holding the metal grate between the color wheel unit and the bulb.
      • Using the Phillips #1 screwdriver, remove the (2) two 2 cm gold screws on the right side of the lens house.
      • Using the Phillips #1 screwdriver and a bent driver, remove the (4) four 2 cm screws on the back of the lens house.
      댓글 쓰기
    2. InFocus Screenplay 4805 Light Tunnel Replacement: 7 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Light Tunnel Replacement: 7 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Light Tunnel Replacement: 7 단계, 이미지 3개 중 3개
      • Using a Phillips #0 screwdriver remove the three 1 cm black screws from the lens house.
      • Remove the lens unit.
      댓글 쓰기
    3. InFocus Screenplay 4805 Light Tunnel Replacement: 8 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Light Tunnel Replacement: 8 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Light Tunnel Replacement: 8 단계, 이미지 3개 중 3개
      • Using the Phillips #0 head, unscrew the four 1 cm black screws.
      • Remove the metal casings holding the tunnel in place.
      댓글 쓰기
    4. InFocus Screenplay 4805 Light Tunnel Replacement: 9 단계, 이미지 2개 중 1개 InFocus Screenplay 4805 Light Tunnel Replacement: 9 단계, 이미지 2개 중 2개
      • Using the Phillips #0 head, unscrew the black 0.5 cm screw on the bottom of the lens house.
      • Remove the light tunnel.
      댓글 쓰기
결론
To reassemble the device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Marilyn Urness
회원 가입일: 09/28/17
671 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 1,168
