주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus Screenplay 4805 Motherboard Replacement
필요한 것
    1. InFocus Screenplay 4805 Motherboard Replacement, Top Panel: 1 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: 1 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: 1 단계, 이미지 3개 중 3개
      • Flip the projector on its back.
      • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
      • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
      댓글 쓰기
    2. InFocus Screenplay 4805 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 InFocus Screenplay 4805 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Turn the projector, facing the back cable board towards you.
      • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
      • Gently take off back cable panel.
      댓글 쓰기
    3. InFocus Screenplay 4805 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Turn the projector so the front side with the lens is facing you.
      • Gently pry the both of the grey lens rings using the metal spudger.
      댓글 쓰기
    4. InFocus Screenplay 4805 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Now that the screws have been removed, proceed with the removal of the outer panel.
      • Gently remove the front lens panel.
      • Be forewarned, the panel will resist. Be careful not to break the lens.
      댓글 쓰기
    5. InFocus Screenplay 4805 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
      • Rest the lid behind the projector so the insides are exposed and undamaged.
      댓글 쓰기
    1. InFocus Screenplay 4805 Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
      • Using the Phillips #1 screwdriver, remove the (4) four 1.5 cm screws on each of the four corners of the motherboard cover.
      • Remove the white tab connected to the light bulb.
      댓글 쓰기
    2. InFocus Screenplay 4805 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
      • Gently pull the white tab on the right side of the silver power housing by pinching each side of it.
      • Pinch the two black tabs on the inside of the cover to remove.
      • Gently pull on the long white tab to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Marilyn Urness
회원 가입일: 09/28/17
671 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 27
전체 시간: 702
