주요 콘텐츠로 건너뛰기
India Mark II Access Door Replacement
필요한 것
  1. India Mark II Access Door Replacement, Access Door: 1 단계, 이미지 1/2 India Mark II Access Door Replacement, Access Door: 1 단계, 이미지 2/2
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark II Access Door Replacement: 2 단계, 이미지 1/3 India Mark II Access Door Replacement: 2 단계, 이미지 2/3 India Mark II Access Door Replacement: 2 단계, 이미지 3/3
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark II Access Door Replacement: 3 단계, 이미지 1/2 India Mark II Access Door Replacement: 3 단계, 이미지 2/2
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,810 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 26
30일 전: 185
전체 시간: 1,625
