소개
Follow this guide to remove the handle and axle of the India Mark II. You can then replace or repair either or both.
필요한 것
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Use a wrench to loosen the nut on the end of the handle axle.
Remove the nut and washer from the end of the axle.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
