소개
This guide will lead you through removing the traveling valve from the pump cylinder. It can then be replaced as a unit, or disassembled further to replace an individual internal component.
필요한 것
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
Pull the assembly of riser main pipe and cylinder out of the well and set the assembly on a block of wood to keep the cylinder off the ground.
Insert a wrench into the slots located at the bottom of the traveling valve.
Using another wrench for leverage, unscrew the valve off the pump rod.
