소개
Follow this guide to remove the axle and the handle from the India Mark III. You can then replace or repair either component.
필요한 것
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Use a wrench to loosen the nut on the end of the handle axle.
Remove the nut and washer from the end of the axle.
거의 끝나갑니다!
결론
