주요 콘텐츠로 건너뛰기
India Mark III Chain Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. India Mark III Chain Replacement, Chain: 1 단계, 이미지 1/3 India Mark III Chain Replacement, Chain: 1 단계, 이미지 2/3 India Mark III Chain Replacement, Chain: 1 단계, 이미지 3/3
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  2. India Mark III Chain Replacement: 2 단계, 이미지 1/3 India Mark III Chain Replacement: 2 단계, 이미지 2/3 India Mark III Chain Replacement: 2 단계, 이미지 3/3
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  3. India Mark III Chain Replacement: 3 단계, 이미지 1/3 India Mark III Chain Replacement: 3 단계, 이미지 2/3 India Mark III Chain Replacement: 3 단계, 이미지 3/3
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  4. India Mark III Chain Replacement: 4 단계, 이미지 1/3 India Mark III Chain Replacement: 4 단계, 이미지 2/3 India Mark III Chain Replacement: 4 단계, 이미지 3/3
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  5. India Mark III Chain Replacement: 5 단계, 이미지 1/3 India Mark III Chain Replacement: 5 단계, 이미지 2/3 India Mark III Chain Replacement: 5 단계, 이미지 3/3
    • Remove the nut from the chain bolt.
  6. India Mark III Chain Replacement: 6 단계, 이미지 1/2 India Mark III Chain Replacement: 6 단계, 이미지 2/2
    • Remove the washer from the chain bolt.
  7. India Mark III Chain Replacement: 7 단계, 이미지 1/2 India Mark III Chain Replacement: 7 단계, 이미지 2/2
    • Remove the chain bolt.
  8. India Mark III Chain Replacement: 8 단계, 이미지 1/3 India Mark III Chain Replacement: 8 단계, 이미지 2/3 India Mark III Chain Replacement: 8 단계, 이미지 3/3
    • Pull the top of the chain straight off of the pump handle.
결론
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,846 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 45
