소개
Follow this guide to remove the foot valve. You can then replace either the entire valve, or individual internal components of the valve.
필요한 것
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
거의 끝나갑니다!
결론
