주요 콘텐츠로 건너뛰기
Infant Optics DXR-5 Monitor Screen Replacement
필요한 것
  1. Infant Optics DXR-5 Monitor Screen Replacement, Battery: 1 단계, 이미지 1/2 Infant Optics DXR-5 Monitor Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Press on the blue clip on the back and slide it down.
    • In the second picture there is a slight gap at the top of the blue clip.
  2. Infant Optics DXR-5 Monitor Screen Replacement: 2 단계, 이미지 1/1
    • Pull the blue clip away from the body of the hand held monitor.
  3. Infant Optics DXR-5 Monitor Screen Replacement: 3 단계, 이미지 1/1
    • Slide the rear white panel off as shown.
  4. Infant Optics DXR-5 Monitor Screen Replacement: 4 단계, 이미지 1/2 Infant Optics DXR-5 Monitor Screen Replacement: 4 단계, 이미지 2/2
    • Remove the battery by pushing in on the right side and then pulling the battery up and out of the body of the hand held monitor.
  5. Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: 5 단계, 이미지 1/3 Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: 5 단계, 이미지 2/3 Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: 5 단계, 이미지 3/3
    • Remove the four 6.0 mm Phillips screws located on the back of the hand held monitor using a Phillips #2 screwdriver.
    • There are two types of screws. Be sure to return the screws to their respective holes upon reassembly.
  6. Infant Optics DXR-5 Monitor Screen Replacement: 6 단계, 이미지 1/2 Infant Optics DXR-5 Monitor Screen Replacement: 6 단계, 이미지 2/2
    • Carefully remove the clear face plate on the front of the hand held monitor using a plastic spudger and a suction cup.
    • Use a heat source to loosen the adhesive around the edge of the face plate before applying any pressure to the face plate.
  7. Infant Optics DXR-5 Monitor Screen Replacement: 7 단계, 이미지 1/2 Infant Optics DXR-5 Monitor Screen Replacement: 7 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that are exposed after removing the face plate.
  8. Infant Optics DXR-5 Monitor Screen Replacement: 8 단계, 이미지 1/2 Infant Optics DXR-5 Monitor Screen Replacement: 8 단계, 이미지 2/2
    • Using a drill carefully drill out the plastic posts that connect the mother board to the face plate.
  9. Infant Optics DXR-5 Monitor Screen Replacement: 9 단계, 이미지 1/2 Infant Optics DXR-5 Monitor Screen Replacement: 9 단계, 이미지 2/2
    • Carefully open the hand held monitor and flip the screen (highlighted in red) out of the way.
  10. Infant Optics DXR-5 Monitor Screen Replacement: 10 단계, 이미지 1/2 Infant Optics DXR-5 Monitor Screen Replacement: 10 단계, 이미지 2/2
    • Remove the hand held monitor screen from the mother board by carefully pulling from the point where it is attached with an adhesive to the mother board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Charles Neal
회원 가입일: 08/31/15
687 평판
안내서 5개 작성하였습니다
USF Tampa, Team 6-2, Remmell Fall 2015 USF Tampa, Team 6-2, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G2
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Any ideas on where to source the replacement screen?
Abdullah - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 15
전체 시간: 1,999
