주요 콘텐츠로 건너뛰기
Infant Optics DXR-8 Back Cover Prerequisite
필요한 것
  1. Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: 1 단계, 이미지 3개 중 1개 Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: 1 단계, 이미지 3개 중 2개 Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: 1 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Back Cover Prerequisite: 2 단계, 이미지 3개 중 1개 Infant Optics DXR-8 Back Cover Prerequisite: 2 단계, 이미지 3개 중 2개 Infant Optics DXR-8 Back Cover Prerequisite: 2 단계, 이미지 3개 중 3개
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Back Cover Prerequisite: 3 단계, 이미지 3개 중 1개 Infant Optics DXR-8 Back Cover Prerequisite: 3 단계, 이미지 3개 중 2개 Infant Optics DXR-8 Back Cover Prerequisite: 3 단계, 이미지 3개 중 3개
    • Disconnect speaker from monitor for ease of access by unplugging wire.
결론
다른 20명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Peyton Ulrich
회원 가입일: 01/24/17
515 평판
안내서 1개를 작성함
Cal Poly, Team 13-4, Banghart Winter 2017 Cal Poly, Team 13-4, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G4
4 회원들
안내서 4개를 작성함
29가이드 댓글
Great walkthrough. One suggestion i have is to make sure to remove the battery before doing any of the disassembly. Great guide!
Derrick Brown - 답글
Any idea where I could buy a replacement screen though? I just dropped mine and the screen is broken. The front plastic is still undamaged.
Jon Woolery - 답글
I bought a Sharp LQ035NC111 LCD Display eBay for $8.46 and it did the trick
Nathaniel Wolf -
Do you know where I could buy a replacement screen for this device? I just dropped mine and the only damage that I can see is a crack in the LCD that is making the image almost entirely unviewable.
Jon Woolery - 답글
I replaced mine with a “3.5" Inch QVGA 240x320 TFT Color LCD Display Module LQ035NC111 54pin” I found on ebay for $8.81, works great.
Just Being Helpful -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 24
지난 30일: 161
전체 시간: 31,923
