주요 콘텐츠로 건너뛰기
Infant Optics DXR-8 Camera Speaker Replacement
필요한 것
  1. Infant Optics DXR-8 Camera Speaker Replacement, Infant Optics DXR-8 Camera Disassembly: 1 단계, 이미지 1/2 Infant Optics DXR-8 Camera Speaker Replacement, Infant Optics DXR-8 Camera Disassembly: 1 단계, 이미지 2/2
    • Position the camera with bottom facing toward you.
    • Using the plastic opening tool, remove all four rubber ends from the bottom of the camera.
  2. Infant Optics DXR-8 Camera Speaker Replacement: 2 단계, 이미지 1/2 Infant Optics DXR-8 Camera Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the four 4 mm screws beneath rubber ends using the Phillips #00 screwdriver.
  3. Infant Optics DXR-8 Camera Speaker Replacement: 3 단계, 이미지 1/1
    • Open the bottom of the camera to reveal the circuit board and speaker.
  4. Infant Optics DXR-8 Camera Speaker Replacement, Camera Speaker: 4 단계, 이미지 1/1
    • Disconnect the speaker cable from the circuit board for ease of access.
  5. Infant Optics DXR-8 Camera Speaker Replacement: 5 단계, 이미지 1/1
    • Lift the speaker from the casing using a metal spudger.
    • Place a new 8W speaker in the casing.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 2,230
