주요 콘텐츠로 건너뛰기
Infant Optics DXR-8 Monitor Screen Replacement
필요한 것
  1. Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: 1 단계, 이미지 3개 중 1개 Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: 1 단계, 이미지 3개 중 2개 Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: 1 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Monitor Screen Replacement: 2 단계, 이미지 3개 중 1개 Infant Optics DXR-8 Monitor Screen Replacement: 2 단계, 이미지 3개 중 2개 Infant Optics DXR-8 Monitor Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Screen Replacement: 3 단계, 이미지 3개 중 1개 Infant Optics DXR-8 Monitor Screen Replacement: 3 단계, 이미지 3개 중 2개 Infant Optics DXR-8 Monitor Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: 4 단계, 이미지 3개 중 1개 Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: 4 단계, 이미지 3개 중 2개 Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: 4 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Screen Replacement: 5 단계, 이미지 2개 중 1개 Infant Optics DXR-8 Monitor Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Screen Replacement: 7 단계, 이미지 3개 중 1개 Infant Optics DXR-8 Monitor Screen Replacement: 7 단계, 이미지 3개 중 2개 Infant Optics DXR-8 Monitor Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
4가이드 댓글
Hey Daniel!
Thanks for sharing ??
Where did you get the replacement part?
Ro Brandi - 답글
On Amazon is the quickest option.
Hilitand LQ035NC111 LCD Display, 3.5inch TFT RGB LCD Display Module 320 x 240 Display Panel LQ035NC111 54pin LCD
Stebe -
Just completed the screen change, it works great! Thanks so much for this step by step guide.
The screen I ordered came with the metal brackets. Since the base was glued to the motherboard, it took a few extra steps of de-casing the one I got and re-casing onto the board. But worked fine.
I ordered: https://www.amazon.com/dp/B07NYN5PK2?psc...
James Quinlan - 답글
Does this improve the brightness of the screen or is it essentially an OEM replacement? I have found the monitor to be basically unusable in daylight conditions (like every midday nap) so I’m hoping to add some anti glare and boost the screen brightness/contrast.
Thanks for the information!
Owen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 91
전체 시간: 5,837
