소개
Replace a faulty speaker.
필요한 것
Using the plastic opening tool, remove screen protector from front of monitor.
Use a heat gun to soften and easily remove epoxy that surrounds the speaker. Gently scrape it free little by little with metal spudger.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 5개
Where to purchase the replacement speaker?
Where can we purchase the replacement 8w speaker part
lea placek - 답글
8W Speaker is incorrect.
The speaker needed is 8 Ohm 0.5 Watt.
Ryan Ernde - 답글
Thanks for this. Found something on Ali Express, just need to figure out the right size
itryit -
This is good to show how you get it open. Unless you have a speaker that has the plastic piece that connects to the mother board, then it’s useless. The speaker I ordered just had two free standing wires.
Mark Ruddy - 답글
