주요 콘텐츠로 건너뛰기
Infinity v2 10.1 Camera Replacement
필요한 것
  1. Infinity v2 10.1 Camera Replacement, Back Case: 1 단계, 이미지 1/3 Infinity v2 10.1 Camera Replacement, Back Case: 1 단계, 이미지 2/3 Infinity v2 10.1 Camera Replacement, Back Case: 1 단계, 이미지 3/3
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Camera Replacement: 2 단계, 이미지 1/2 Infinity v2 10.1 Camera Replacement: 2 단계, 이미지 2/2
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Camera Replacement, Camera: 3 단계, 이미지 1/1
    • Use your thumb or opening tool to lift the black connector holding in the ribbon cable.
  4. Infinity v2 10.1 Camera Replacement: 4 단계, 이미지 1/1
    • Remove the camera by gently picking it up and pulling it free from the connector.
    • Avoid touching the lens of either camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
sammytarbokas
회원 가입일: 10/31/19
193 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 UMass Dartmouth, Team S2-G4, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 12
전체 시간: 124
