소개
The Infinity v2 10.1 camera should be replaced when it no longer turns on, the lens is cracked or water damaged, or when it takes a distorted image. Replacing the camera is a simple process, without any previous repair experience required. You will simply disconnect the camera from the motherboard, which you can do using your fingers. All you will need is a tool to open the device and a new camera to replace with the old one.
필요한 것
Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
Use your thumb or opening tool to lift the black connector holding in the ribbon cable.
다른 한 분이 해당 안내서를 완성하였습니다.
