주요 콘텐츠로 건너뛰기
Infinity v2 10.1 Speakers Replacement
필요한 것
  1. Infinity v2 10.1 Speakers Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Infinity v2 10.1 Speakers Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Infinity v2 10.1 Speakers Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Speakers Replacement: 2 단계, 이미지 2개 중 1개 Infinity v2 10.1 Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Speakers Replacement, Speakers: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Turn on your soldering iron and allow it to heat up. Once it is hot, press the tip of the iron to the both of the solder points that attach the wires to the motherboard until the solder is melted.
    • Once the solder is melted, use tweezers to remove the wires from the motherboard.
    • The solder and iron will be extremely hot. You can use tweezers to grab the wire to avoid burning your fingers from accidental contact with the iron.
결론
작성자
6다른 기여자 명과 함께
Nate Rice
회원 가입일: 10/31/19
321 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 UMass Dartmouth, Team S2-G4, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 251
