부품
부품은 필요하지 않습니다.
  1. Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • To ensure you don't lose any tiny parts during the replacement process, place parts on the white magnetic sheet.
    • Once the screws have been removed, proceed to take off back cover.
  2. Now, proceed to lift the battery out and remove it.
    • Now, proceed to lift the battery out and remove it.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
    • Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
  5. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
    • Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
  6. Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary. Pull the motherboard out and down away from the top of the phone.
    • Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary.
    • Pull the motherboard out and down away from the top of the phone.
결론
Lauren
회원 가입일: 2014년 02월 13일
43 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-4, Buehl Spring 2014 Ohio State, Team 1-4, Buehl Spring 2014 회원
OSU-BUEHL-S14S1G4
3 회원들
안내서 3개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 428
