소개
You'll probably never need to diagnose an instrument light problem with your car, but that doesn't mean you can't have fun performing this test. And knowing that the gauges and lights are working is reassuring.
If you want to show this to friends, be warned that HID headlights service life can be reduced by turning them on and off needlessly. The bulbs aren't cheap. I recommend pulling the fuses for them before doing this repeated.
This procedure is specific to HONDAs and ACURAs.
도구
지정된 도구가 없습니다.
부품
This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
Within 5 seconds, release the Sel/reset button.
Push and release the Sel/reset button button 3 times repeatedly.
Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 2개
Folks, don’t post here asking about A COMPLETELY DIFFERENT VEHICLE. This page is for the 2004-2008 Acura TSX (Honda CL9), no others. Keep searching.
