주요 콘텐츠로 건너뛰기
Initiate the instrument cluster self-test
필요한 것
  1. Initiate the instrument cluster self-test, Save the headlights from excessive use: 1 단계, 이미지 1/1
    • This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • Be sure to reinstall the low beam headlight fuses before driving the vehicle.
  2. Initiate the instrument cluster self-test, Starting the self test inputs: 2 단계, 이미지 1/3 Initiate the instrument cluster self-test, Starting the self test inputs: 2 단계, 이미지 2/3 Initiate the instrument cluster self-test, Starting the self test inputs: 2 단계, 이미지 3/3
    • Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
    • Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
  3. Initiate the instrument cluster self-test: 3 단계, 이미지 1/1
    • Turn the headlights ON.
  4. Initiate the instrument cluster self-test: 4 단계, 이미지 1/2 Initiate the instrument cluster self-test: 4 단계, 이미지 2/2
    • Turn the ignition switch to ON (position II).
    • Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
  5. Initiate the instrument cluster self-test: 5 단계, 이미지 1/3 Initiate the instrument cluster self-test: 5 단계, 이미지 2/3 Initiate the instrument cluster self-test: 5 단계, 이미지 3/3
    • Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
  6. Initiate the instrument cluster self-test, Final inputs, and here comes the show: 6 단계, 이미지 1/3 Initiate the instrument cluster self-test, Final inputs, and here comes the show: 6 단계, 이미지 2/3 Initiate the instrument cluster self-test, Final inputs, and here comes the show: 6 단계, 이미지 3/3
    • Within 5 seconds, release the Sel/reset button.
    • Push and release the Sel/reset button button 3 times repeatedly.
    • The instrument cluster begins its self-test.
    • Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
    • To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
    • If you removed the 15A headlight fuses from the under-hood fuse box in step 1, reinstall them before driving.
    How do I relearn my cluster on my 05 chev verturr I did Mark the niddle
    Larry Treynor - 답글
    I didn't mark the needle before I took apart to put speedmotor how do I get it right
    Larry Treynor - 답글
    Wrong vehicle, dude. Hope you figured it out or got a friend to help out.
    David Spalding - 답글
    Can I do this to my 03 Chevy
    joshuam1986 - 답글
결승점
다른 15명이 해당 안내서를 완성하였습니다.
David Spalding
회원 가입일: 11/12/15
6,470 평판
안내서 12개 작성하였습니다
댓글 3개
Folks, don’t post here asking about A COMPLETELY DIFFERENT VEHICLE. This page is for the 2004-2008 Acura TSX (Honda CL9), no others. Keep searching.
David Spalding - 답글
I left decklid open overnight and now my instrument panel is not working
Anthony - 답글
I have an 08 Acura TSX. The lights on the dash are flashing on and off. None of the guages work, neither does the heater. when I plug in my OBD, it throws a U0155 code, lost communication with the instrument panel cluster. The funny thing is, when I plug in the OBD, the instrument cluster work fine, as well as the heat. Please help!
John Dolan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 37
7일 전: 263
30일 전: 947
전체 시간: 310,739
