주요 콘텐츠로 건너뛰기
Insignia 6-Quart Pressure Cooker Circuit Board Replacement
필요한 것
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: 1 단계, 이미지 1/1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 2 단계, 이미지 1/1
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 3 단계, 이미지 1/1
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 4 단계, 이미지 1/1
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 5 단계, 이미지 1/1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 6 단계, 이미지 1/1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 7 단계, 이미지 1/1
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 8 단계, 이미지 1/1
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 9 단계, 이미지 1/1
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 10 단계, 이미지 1/1
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 11 단계, 이미지 1/1
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 12 단계, 이미지 1/1
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 13 단계, 이미지 1/1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 14 단계, 이미지 1/1
    • Remove and replace the circuit board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Savannah Webb
회원 가입일: 01/18/18
657 평판
안내서 5개 작성하였습니다
Cal Poly, Team S12-G3, Banghart Winter 2018 Cal Poly, Team S12-G3, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G3
4 회원들
안내서 5개 작성하였습니다
댓글 8개
Where do you purchase the circuit board
Douglas Koons - 답글
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - 답글
Please, Where can I buy the electrical circuit?
Mohammed - 답글
why is my circuit board not fixed to the top like in the diagram
david stanley - 답글
where can I purchase the circuit board
de27@bellsouth.net - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 25
전체 시간: 3,163
