주요 콘텐츠로 건너뛰기
Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: 1 단계, 이미지 1/1
    • Remove the lid and place it upside-down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: 2 단계, 이미지 1/1
    • Pinch the rubber gasket on the float valve and pull up.
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: 3 단계, 이미지 1/2 Insignia 6-Quart Pressure Cooker Float Valve Replacement: 3 단계, 이미지 2/2
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Savannah Webb
회원 가입일: 01/18/18
657 평판
안내서 5개 작성하였습니다
Cal Poly, Team S12-G3, Banghart Winter 2018 Cal Poly, Team S12-G3, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G3
4 회원들
안내서 5개 작성하였습니다
댓글 2개
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - 답글
OK after much digging, I found the old valve and now it is pressurizing.
Carole Neider - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 74
전체 시간: 4,370
