주요 콘텐츠로 건너뛰기
Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement
  1. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement, Rubber Gasket: 1 단계, 이미지 1/1
    • Remove lid and place upside down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: 2 단계, 이미지 1/2 Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: 2 단계, 이미지 2/2
    • Grab the edge of the clear rubber gasket and slowly peel it off the lid.
    • Continue peeling off the gasket until it is completely detached from the lid.
결론
Savannah Webb
회원 가입일: 01/18/18
657 평판
안내서 5개 작성하였습니다
Cal Poly, Team S12-G3, Banghart Winter 2018 Cal Poly, Team S12-G3, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G3
4 회원들
안내서 5개 작성하였습니다
댓글 3개
Am having trouble Turning the lid from Unlock to lock. The pin comes out in the back when I go to turn it from unlock to lock. Can you help me?
pclarkrob3 - 답글
I bought the insignia pressure cooker at a garage sale but, the rubber gasket smells bad. I’ve cleaned the entire cooker but, that gasket stinks like no other
Chuck Smith - 답글
I am having the same problem as the first comment by pclarkrob3 I am having trouble turning the lid from unlock to lock. These are really crappy instructions!!!! I have only used my pressure cooker twice so everything is still new.
Vivian Lang - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,240
