주요 콘텐츠로 건너뛰기
Insignia Flex 10.1 NS-P10A7100 Battery Replacement
필요한 것
  1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: 1 단계, 이미지 1/3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: 1 단계, 이미지 2/3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Use the blue iFixit opening tool to remove the backing of the device.
    • Wedge the tool in the crease between the device backing and screen.
  2. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: 2 단계, 이미지 1/2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: 2 단계, 이미지 2/2
    • Disconnect the larger ribbon that runs along the top of the battery and connects to the motherboard.
    • Lift up the connector by pulling it up with your fingernail. The ribbon will then be released and you can detach it.
  3. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: 3 단계, 이미지 1/2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: 3 단계, 이미지 2/2
    • Detach the five colored wires that connect the battery to the motherboard.
    • Use two fingers and place one on either side of the white plastic encasing the wires.
    • Pull on this piece to release it from the motherboard.
    • Now the battery is detached from the motherboard.
  4. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: 4 단계, 이미지 1/3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: 4 단계, 이미지 2/3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: 4 단계, 이미지 3/3
    • The battery is now only connected to the device by the glue on the bottom.
    • Use the iFixit opening tool to wedge the battery off of the device. You will have to use some force to pry the battery off of the device.
    • Now that your battery is removed it is ready for replacement.
결론
Hannah
회원 가입일: 02/05/19
289 평판
안내서 1개 작성함
University of Michigan, Team S1-G3, Li Winter 2019 University of Michigan, Team S1-G3, Li Winter 2019 회원
UMIC-LI-W19S1G3
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 17
전체 시간: 971
