소개
The keyboard connector in the Insignia Flex 10.1 NS-P10W8100 is located on a ribbon cable connected to the motherboard. Although there are no major hazards with this replacement guide, be careful not to pull ribbon cables too hard as they can be damaged easily.
필요한 것
Carefully open the laptop and remove the keyboard by disconnecting it.
Place keyboard to the side as you will not need it.
다른 한 분이 해당 안내서를 완성하였습니다.
