주요 콘텐츠로 건너뛰기
Insignia Flex 10.1 NS-P16AT10 Camera Replacement
필요한 것
  1. Insignia Flex 10.1 NS-P16AT10 Camera Replacement, Camera: 1 단계, 이미지 1/2 Insignia Flex 10.1 NS-P16AT10 Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Make sure your device is off and not connected to any power sources to avoid injury
    • Use a plastic opening tool to remove the rear panel from the front case.
    • Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
    • The volume rocker and power button will become free from the device when the front and rear panels are separated from each other. Do not worry. These pieces are easily put back into place when reassembling the tablet.
  2. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 2 단계, 이미지 1/2 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to flip up the ribbon connector that connects the camera to the motherboard.
    • Free the ribbon cable from the motherboard.
  3. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 3 단계, 이미지 1/2 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 3 단계, 이미지 2/2
    • Use a #00 Phillips head screw driver to remove the two screws that hold the camera down to the front case.
  4. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers or your fingers to remove the camera from your Insignia Flex 10.1 NS-P16AT10.
  5. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 5 단계, 이미지 1/2 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 5 단계, 이미지 2/2
    • The camera is now free and ready to be replaced.
결론
Morgan Kidd
회원 가입일: 10/10/16
419 평판
안내서 3개 작성하였습니다
Texas Tech, Team 12-3, Bennett Fall 2016 Texas Tech, Team 12-3, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 156
