소개
If your Insignia Flex 11.6 is not holding a charge or is not starting up, use this guide in replacing the battery.
필요한 것
Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
이 단계에 사용된 도구:Plastic Cards$2.99
The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
Hi, great tutorial - thanks! Just wondering where you sourced the replacement battery? I've looked high and low googling but can't seem to find anywhere that sells them.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 6개
There are no screws on the bottom edge of my invicta model P11A8100. Can I bypass removing screws and proceed to removing the back?
There are no screws on the bottom of my model P11A8100. Can I bypass removal is said screws and proceed to opening the back?
Great instructions but I cant find a battery replacement. Battery number 3394122-2p
Great instructions but now I cant find the battery anywhere it is 3394122-2p
Saludos, necesito instalar el driver: Batería con método de control compatible con ACPI de microsoft, que me hace falta en mi tablet, flex 11.6 con w10 32 bits. mi correo: tnnaguiar@gmail.com
