주요 콘텐츠로 건너뛰기
Insignia Flex 7 Battery Replacement
필요한 것
  1. Insignia Flex 7 Battery Replacement, Battery: 1 단계, 이미지 1/3 Insignia Flex 7 Battery Replacement, Battery: 1 단계, 이미지 2/3 Insignia Flex 7 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Battery Replacement: 2 단계, 이미지 1/2 Insignia Flex 7 Battery Replacement: 2 단계, 이미지 2/2
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Battery Replacement: 3 단계, 이미지 1/3 Insignia Flex 7 Battery Replacement: 3 단계, 이미지 2/3 Insignia Flex 7 Battery Replacement: 3 단계, 이미지 3/3
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jonathan May
회원 가입일: 09/28/15
307 평판
안내서 1개 작성함
댓글 2개
Link for replacement battery?
Mike - 답글
I'm also looking for a replacement battery and i've only found batteries with two cables instead of the 5 this one has
Jose Garza Lozano - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 10
전체 시간: 946
