주요 콘텐츠로 건너뛰기
Insignia Flex 7 Speaker Replacement
필요한 것
  1. Insignia Flex 7 Speaker Replacement, Battery: 1 단계, 이미지 1/3 Insignia Flex 7 Speaker Replacement, Battery: 1 단계, 이미지 2/3 Insignia Flex 7 Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Speaker Replacement: 2 단계, 이미지 1/2 Insignia Flex 7 Speaker Replacement: 2 단계, 이미지 2/2
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Speaker Replacement: 3 단계, 이미지 1/3 Insignia Flex 7 Speaker Replacement: 3 단계, 이미지 2/3 Insignia Flex 7 Speaker Replacement: 3 단계, 이미지 3/3
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
  4. Insignia Flex 7 Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the two 3.0mm long screws shown in the illustration.
  5. Insignia Flex 7 Speaker Replacement: 5 단계, 이미지 1/1
    • Using the spudger, gently pry the speaker from it’s plastic socket.
  6. Insignia Flex 7 Speaker Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Apply heat to the solder junction of the red wire with a solder iron.
    • Once the solder melts, the wire can be disconnected from the circuit board. To do so, use tweezers to apply a gentle tension to the wire when the solder appears fluid.
    • During reassembly, the reversal of this step is slightly different. First, apply heat with the iron, then place the wire on the solder pin. Once the solder flows over the wire, pull the iron away and wait for the solder to solidify.
  7. Insignia Flex 7 Speaker Replacement: 7 단계, 이미지 1/1
    • Repeat the previous step to separate the speaker's black wire from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lorna Harris
회원 가입일: 09/28/15
154 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 225
