주요 콘텐츠로 건너뛰기
Insignia Flex 8 NS-15AT08 Back Casing Replacement
필요한 것
  1. Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: 1 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: 1 단계, 이미지 2/2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Back Casing Replacement: 2 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Back Casing Replacement: 2 단계, 이미지 2/2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
결론
Krystal Rhodes
회원 가입일: 09/22/15
488 평판
안내서 3개 작성하였습니다
Baylor, Team 6-7, Williams Fall 2015 Baylor, Team 6-7, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 465
