주요 콘텐츠로 건너뛰기
Insignia Flex 8 NS-15AT08 Battery Replacement
필요한 것
  1. Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: 1 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: 1 단계, 이미지 2/2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Battery Replacement: 2 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Battery Replacement: 2 단계, 이미지 2/2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: 3 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Wedge a plastic opening tool in between the male, black module and female, white module to disconnect the wires module from the circuit board.
  4. Insignia Flex 8 NS-15AT08 Battery Replacement: 4 단계, 이미지 1/3 Insignia Flex 8 NS-15AT08 Battery Replacement: 4 단계, 이미지 2/3 Insignia Flex 8 NS-15AT08 Battery Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool to pry the battery from the circuit board by wedging it around the perimeter of the battery.
  5. Insignia Flex 8 NS-15AT08 Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the circuit board by lifting it with the spudger or finger.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jeremy Anaya
회원 가입일: 09/23/15
316 평판
안내서 2개 작성하였습니다
Baylor, Team 6-7, Williams Fall 2015 Baylor, Team 6-7, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,918
