주요 콘텐츠로 건너뛰기
Insignia Flex 8 NS-15AT08 Cameras Replacement
필요한 것
  1. Insignia Flex 8 NS-15AT08 Cameras Replacement, Back Casing: 1 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Cameras Replacement, Back Casing: 1 단계, 이미지 2/2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Cameras Replacement: 2 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Cameras Replacement: 2 단계, 이미지 2/2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Insignia Flex 8 NS-15AT08 Cameras Replacement, Cameras: 3 단계, 이미지 1/1
    • Use a plastic opening tool to flip up the black strip that is holding the orange camera ribbon near the module on the circuit board labeled "front camera" in white print.
    • Repeat this action on the orange camera ribbon near the module on the circuit board labeled "back camera" in white print.
  4. Insignia Flex 8 NS-15AT08 Cameras Replacement: 4 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Cameras Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently pull on both orange camera ribbons in the opposite direction in which they are connected until they disconnect from the modules on the circuit board.
  5. Insignia Flex 8 NS-15AT08 Cameras Replacement: 5 단계, 이미지 1/2 Insignia Flex 8 NS-15AT08 Cameras Replacement: 5 단계, 이미지 2/2
    • Peel off the grey tape covering the ribbons, in order to separate the cameras and their respective ribbons from the rest of the device.
    • Do not use excessive force while removing the tape to prevent tears in the ribbons.
  6. Insignia Flex 8 NS-15AT08 Cameras Replacement: 6 단계, 이미지 1/1
    • Use a a plastic opening tool to pry out the back camera at the top of the circuit board.
결론
Krystal Rhodes
회원 가입일: 09/22/15
488 평판
안내서 3개 작성하였습니다
Baylor, Team 6-7, Williams Fall 2015 Baylor, Team 6-7, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 215
