주요 콘텐츠로 건너뛰기
Insignia Flex 8 NS-P16AT08 Battery Replacement
필요한 것
  1. Insignia Flex 8 NS-P16AT08 Battery Replacement, Back Casing: 1 단계, 이미지 1/3 Insignia Flex 8 NS-P16AT08 Battery Replacement, Back Casing: 1 단계, 이미지 2/3 Insignia Flex 8 NS-P16AT08 Battery Replacement, Back Casing: 1 단계, 이미지 3/3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Battery Replacement: 2 단계, 이미지 1/1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Gently peel the tape that is covering the cable connections going to and from the battery and set tape aside.
    • This will expose the cable connections in preparation for disconnecting the cables and battery.
  4. Insignia Flex 8 NS-P16AT08 Battery Replacement: 4 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Battery Replacement: 4 단계, 이미지 2/2
    • Locate battery cable connection.
    • Pull gently on cable that connects the battery to the motherboard.
    • Cable will stay attached to battery but be removed from motherboard.
    • If pulling gently doesn't loosen cable, wiggle connection while pulling gently.
  5. Insignia Flex 8 NS-P16AT08 Battery Replacement: 5 단계, 이미지 1/1
    • Slide the nylon spudger gently underneath the battery.
    • Using the nylon spudger, gently pry battery from adhesive on metal base.
    • Do not puncture or bend battery.
    • Working around the battery, pry up all the sides to remove the battery from the metal base.
    • The adhesive is very strong. Separating the battery from the metal base may be difficult.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Emily Guidinger
회원 가입일: 04/01/16
527 평판
안내서 4개 작성하였습니다
댓글 5개
We're do u get a new battery from ???
stephanie maxwell - 답글
i know this is an old comment but the solution is the same, ebay the model number and you will find many parts for cheap! good luck!
mathew -
i replaced the battery for a customer and now the tablet is stuck at boot hmmm.....
mathew - 답글
after about 3 minutes the device booted apparently I am just too impatient, still another happy customer, thanks!
mathew -
Pls help me to  send me the phone number of the above mentioned Mattew or give him my phone number. I will discuss with him  to replace my charger plug and possibly the battery. thanks.
tesfay gmichael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 3,272
