주요 콘텐츠로 건너뛰기
Insignia Flex 8 NS-P16AT08 Cameras Replacement
필요한 것
  1. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 1 단계, 이미지 1/3 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 1 단계, 이미지 2/3 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 1 단계, 이미지 3/3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 2 단계, 이미지 1/1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Cameras: 3 단계, 이미지 1/1
    • Gently peel all of the tape that is covering the cable connections going to and from the cameras. Set the tape aside for later reassembly.
  4. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 4 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Cameras Replacement: 4 단계, 이미지 2/2
    • Locate camera ribbon connector.
    • Using finger flip up black flap of camera ribbon connector.
  5. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 5 단계, 이미지 1/1
    • Gently pull camera connector ribbon by hand until it separates from connector.
  6. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 6 단계, 이미지 1/1
    • Using metal spudger tool, gently pry right speaker away from adhesive.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • Move right speaker to left side of device so you can freely access the camera ribbon.
  7. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 7 단계, 이미지 1/1
    • Using metal spudger tool, gently pry the rear-facing camera from the adhesive.
  8. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 8 단계, 이미지 1/1
    • Lift up connector ribbon that is attached to the cameras.
    • Slide cameras and connector ribbon out from underneath the speaker cords and battery.
  9. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 9 단계, 이미지 1/1
    • Remove connector ribbon and cameras from device casing.
결론
Emily Guidinger
회원 가입일: 04/01/16
527 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 240
