주요 콘텐츠로 건너뛰기
Insignia Flex 8 NS-P16AT08 Screen Replacement
필요한 것
  1. Insignia Flex 8 NS-P16AT08 Screen Replacement, Back Casing: 1 단계, 이미지 1/3 Insignia Flex 8 NS-P16AT08 Screen Replacement, Back Casing: 1 단계, 이미지 2/3 Insignia Flex 8 NS-P16AT08 Screen Replacement, Back Casing: 1 단계, 이미지 3/3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Screen Replacement: 2 단계, 이미지 1/1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Screen Replacement, Screen: 3 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Screen Replacement, Screen: 3 단계, 이미지 2/2
    • Pull gently on the cable that connects the microphone to the motherboard.
    • The microphone will stay attached to device and separated from motherboard.
  4. Insignia Flex 8 NS-P16AT08 Screen Replacement: 4 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Screen Replacement: 4 단계, 이미지 2/2
    • Flip up the black flap of the connector ribbon that connects the screen to the motherboard.
    • Connector ribbon will stay attached to the device and separted from the motherboard.
    • If the black flap of connector will not lift by using your finger, then use the nylon spudger.
  5. Insignia Flex 8 NS-P16AT08 Screen Replacement: 5 단계, 이미지 1/1
    • Gently pull the connector ribbon by hand from the connector until it separates from connector.
  6. Insignia Flex 8 NS-P16AT08 Screen Replacement: 6 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Screen Replacement: 6 단계, 이미지 2/2
    • Flip up the black flap of the connector ribbon that connects the buttons to the motherboard.
    • The connector ribbon will stay attached to the device and separted from the motherboard.
    • If the black flap of the connector will not lift by using your finger, then use the nylon spudger.
  7. Insignia Flex 8 NS-P16AT08 Screen Replacement: 7 단계, 이미지 1/1
    • Gently pull the connector ribbon by hand from the connector until it separates from the connector.
  8. Insignia Flex 8 NS-P16AT08 Screen Replacement: 8 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Screen Replacement: 8 단계, 이미지 2/2
    • Gently pry the cameras from device using metal spudger tool.
    • Always try using a plastic opening tool or nylon spudger first. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • The cameras and connector ribbon will stay attached to motherboard.
  9. Insignia Flex 8 NS-P16AT08 Screen Replacement: 9 단계, 이미지 1/1
    • Remove the tape that is covering the screen motherboard connector ribbon.
    • The screen connection will now be exposed.
  10. Insignia Flex 8 NS-P16AT08 Screen Replacement: 10 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Screen Replacement: 10 단계, 이미지 2/2
    • Flip up the black flap of the connector that connects the screen to the motherboard.
    • The connector ribbon will remain attached to the motherboard and separated from the screen.
  11. Insignia Flex 8 NS-P16AT08 Screen Replacement: 11 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Screen Replacement: 11 단계, 이미지 2/2
    • Using a PH00 screwdriver, remove the (7) seven silver screws that connect the metal plate to the device.
    • Using a PH00 screwdriver, remove the (3) three black screws that connect the motherboard to the device.
  12. Insignia Flex 8 NS-P16AT08 Screen Replacement: 12 단계, 이미지 1/1
    • Gently lift the metal plate that is attached to the motherboard and battery and set aside.
    • Do not force the metal plate to separate from the screen!
    • If the metal plate does not separate from device freely, then you have not disconnected a connector ribbon or you have not removed all the screws. Repeat step 10.
    • Screen will now be exposed.
결론
Emily Guidinger
회원 가입일: 04/01/16
527 평판
안내서 4개 작성하였습니다
댓글 한 개
Where to buy it the display?
krnes1979 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 854
