주요 콘텐츠로 건너뛰기
Insignia Flex 8 NS-P16AT08 Speakers Replacement
필요한 것
  1. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 1 단계, 이미지 1/3 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 1 단계, 이미지 2/3 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 1 단계, 이미지 3/3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 2 단계, 이미지 1/1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: 3 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: 3 단계, 이미지 2/2
    • There are two connections that attach the speakers to the motherboard.
    • Unplug the cables from the motherboard by gently pulling them away.
    • Speaker cables will be free to be removed.
  4. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 4 단계, 이미지 1/2 Insignia Flex 8 NS-P16AT08 Speakers Replacement: 4 단계, 이미지 2/2
    • Remove the tape that is holding the speaker cables down.
    • Remove the speaker cables from underneath the black connector ribbons.
    • The cables are hooked underneath black connector ribbons; carefully unhook them.
  5. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 5 단계, 이미지 1/1
    • Gently pry both speakers away from adhesive with metal spudger tool.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • The speakers can now be completely removed from the device.
결론
Jose Diaz
회원 가입일: 04/03/16
20 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 228
