주요 콘텐츠로 건너뛰기
Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement
필요한 것
  1. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement, Water Tray: 1 단계, 이미지 1/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement, Water Tray: 1 단계, 이미지 2/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement, Water Tray: 1 단계, 이미지 3/3
    • Remove the 6 screws holding the rear casing on.
    • Remove the rear casing
  2. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 2 단계, 이미지 1/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 2 단계, 이미지 2/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 2 단계, 이미지 3/3
    • Remove the 4 screws holding the Ice Tray to the body of the Ice Maker.
  3. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 3 단계, 이미지 1/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 3 단계, 이미지 2/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 3 단계, 이미지 3/3
    • Remove the 4 screws holding the Ice Tray from the top.
  4. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 4 단계, 이미지 1/2 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 4 단계, 이미지 2/2
    • Lift the Water Pump out of the way
  5. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 5 단계, 이미지 1/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 5 단계, 이미지 2/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 5 단계, 이미지 3/3
    • Remove the final 2 screws.
  6. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 6 단계, 이미지 1/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 6 단계, 이미지 2/3 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: 6 단계, 이미지 3/3
    • Remove the plastic cover from the circuit board by pressing the lever on the side. A pry tool may be required.
    • Disconnect the water tray cord.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Evan Taylor
회원 가입일: 01/18/18
616 평판
안내서 5개 작성하였습니다
Cal Poly, Team S21-G3, Banghart Winter 2018 Cal Poly, Team S21-G3, Banghart Winter 2018 회원
CPSU-BANGHART-W18S21G3
2 회원들
안내서 5개 작성하였습니다
댓글 3개
Where do I find insignia ice maker ns- imp26ss7 replacement ice forming tray? Can't locate item on the internet.
razorbllade - 답글
I found a seller on ebay that has 7 of them and is selling them for $20 shipped
er.vanlaarhoven -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 75
전체 시간: 3,107
