주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Insignia NS-15MS0832B Power Button Replacement
필요한 것
  1. Insignia NS-15MS0832B Power Button Replacement, Power Button: 1 단계, 이미지 1개 중 1개
    • The power button is located on the top side on the tablet, along side the charging port and MicroUSB port
  2. Insignia NS-15MS0832B Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Starting in the corner, carefully insert the plastic opening tool.
    • Work the plastic opening tool carefully around the entire device to pry it open.
  3. Insignia NS-15MS0832B Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • Once the tablet is completely open, set aside the back half.
    • Carefully place the other half of the tablet screen-side down.
  4. Insignia NS-15MS0832B Power Button Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, gently grab the power button and pull it out from the tablet.
  5. Insignia NS-15MS0832B Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Once the faulty power button is removed, follow the directions in reverse order to reassemble the device.
결론
작성자
3다른 기여자 명과 함께
Harrison Smith
회원 가입일: 10/19/16
329 평판
안내서 3개를 작성함
Texas Tech, Team 1-1, Bennett Fall 2016 Texas Tech, Team 1-1, Bennett Fall 2016 회원
TTU-BENNETT-F16S1G1
4 회원들
안내서 6개를 작성함
2가이드 댓글
If the power button doesn’t physically click anymore, can you order a replacement? Is it even possible to solder on a new power button?
Thanks in advance…
Chris - 답글 공유
Can you do this with the volume rocker? My Insignia tablet has a faulty rocker, and I need to fix it. (Note- the “+” part of the volume button sticks and jams the volume to 100 until I press “-”.)
Andy Joonseo Bae - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 1,242
