주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Insignia NS-15MS0832B Speaker Replacement
필요한 것
  1. Insignia NS-15MS0832B Speaker  Replacement, Speakers: 1 단계, 이미지 1개 중 1개
    • Begin the speaker replacement by inserting the plastic opening tool into the corner of the device.
    • Work the plastic opening tool along the edge until you have separated the screen from the back plate.
  2. Insignia NS-15MS0832B Speaker  Replacement: 2 단계, 이미지 1개 중 1개
    • Once the backplate is separated from the screen it should look like this.
  3. Insignia NS-15MS0832B Speaker  Replacement: 3 단계, 이미지 1개 중 1개
    • Gently set the tablet screen-side down.
    • The speakers can be located at the bottom of the tablet, below the battery.
    • Using a screwdriver, remove the five 1.2 mm Phillips #1 screws that hold the speakers to the tablet.
  4. Insignia NS-15MS0832B Speaker  Replacement: 4 단계, 이미지 1개 중 1개
    • Once first speaker has been removed, remove the other speaker opposite from it.
  5. Insignia NS-15MS0832B Speaker  Replacement: 5 단계, 이미지 1개 중 1개
    • Once faulty speakers have been unscrewed, disconnect the speaker and attach the new speaker to the mother board.
결론
작성자
3다른 기여자 명과 함께
Harrison Smith
회원 가입일: 10/19/16
329 평판
안내서 3개를 작성함
Texas Tech, Team 1-1, Bennett Fall 2016 Texas Tech, Team 1-1, Bennett Fall 2016 회원
TTU-BENNETT-F16S1G1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 323
