주요 콘텐츠로 건너뛰기
Insignia NS-24ER310NA17 Infrared Sensor Replacement
필요한 것
  1. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Remove the base: 1 단계, 이미지 1/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Remove the base: 1 단계, 이미지 2/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Remove the base: 1 단계, 이미지 3/3
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 2 단계, 이미지 1/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement: 2 단계, 이미지 2/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement: 2 단계, 이미지 3/3
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Pry the TV open: 3 단계, 이미지 1/1
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: 4 단계, 이미지 1/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: 4 단계, 이미지 2/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: 4 단계, 이미지 3/3
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 5 단계, 이미지 1/1
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Motherboard: 6 단계, 이미지 1/1
    • Remove all strips of tape attached to the silver steel rectangular piece.
  7. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 7 단계, 이미지 1/1
    • Pull the red wire out from under the black plastic clip.
  8. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 8 단계, 이미지 1/2 Insignia NS-24ER310NA17 Infrared Sensor Replacement: 8 단계, 이미지 2/2
    • Unscrew the four screws surrounding the steel rectangle with a Phillips 00 Screwdriver.
  9. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 9 단계, 이미지 1/1
    • Carefully lift the rectangular piece.
  10. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 10 단계, 이미지 1/1
    • The rectangular piece will still be attached to the motherboard beneath it with a strip of tape. Remove this strip of tape.
  11. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 11 단계, 이미지 1/2 Insignia NS-24ER310NA17 Infrared Sensor Replacement: 11 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the two screws on both sides of the motherboard.
  12. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 12 단계, 이미지 1/1
    • Carefully lift the motherboard away from the television.
    • Keep in mind that the motherboard is still attached by several thin wires and should not be tugged.
  13. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 13 단계, 이미지 1/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement: 13 단계, 이미지 2/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement: 13 단계, 이미지 3/3
    • There are 5 wires attached to the motherboard. Remove the two thicker white wires to the right of the red wire.
  14. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 14 단계, 이미지 1/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement: 14 단계, 이미지 2/3 Insignia NS-24ER310NA17 Infrared Sensor Replacement: 14 단계, 이미지 3/3
    • Remove the remaining three wires from the mainboard.
  15. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 15 단계, 이미지 1/1
    • Carefully remove the mainboard from the television.
    • You have now successfully removed the mainboard.
  16. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Infrared Sensor: 16 단계, 이미지 1/2 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Infrared Sensor: 16 단계, 이미지 2/2
    • Unscrew single screw holding IR sensor and remove sensor with ribbon cable.
    • Place the new sensor where the old one was and replace the screw.
  17. Insignia NS-24ER310NA17 Infrared Sensor Replacement: 17 단계, 이미지 1/1
    • Plug the new sensor's cable into the motherboard. Make sure to plug it into the correct location.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joelle Hylton
회원 가입일: 01/22/18
260 평판
안내서 1개 작성함
Cal Poly, Team S16-G2, Banghart Winter 2018 Cal Poly, Team S16-G2, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 57
전체 시간: 4,060
