주요 콘텐츠로 건너뛰기
Insignia NS-24ER310NA17 Speaker Replacement
필요한 것
  1. Insignia NS-24ER310NA17 Speaker Replacement, Insignia NS-24ER310NA17: 1 단계, 이미지 1/3 Insignia NS-24ER310NA17 Speaker Replacement, Insignia NS-24ER310NA17: 1 단계, 이미지 2/3 Insignia NS-24ER310NA17 Speaker Replacement, Insignia NS-24ER310NA17: 1 단계, 이미지 3/3
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to remove the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Speaker Replacement: 2 단계, 이미지 1/3 Insignia NS-24ER310NA17 Speaker Replacement: 2 단계, 이미지 2/3 Insignia NS-24ER310NA17 Speaker Replacement: 2 단계, 이미지 3/3
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Speaker Replacement, Pry the TV open: 3 단계, 이미지 1/1
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Speaker Replacement, Disconnect wires: 4 단계, 이미지 1/3 Insignia NS-24ER310NA17 Speaker Replacement, Disconnect wires: 4 단계, 이미지 2/3 Insignia NS-24ER310NA17 Speaker Replacement, Disconnect wires: 4 단계, 이미지 3/3
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Speaker Replacement: 5 단계, 이미지 1/1
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia NS-24ER310NA17 Speaker Replacement, Speaker: 6 단계, 이미지 1/2 Insignia NS-24ER310NA17 Speaker Replacement, Speaker: 6 단계, 이미지 2/2
    • Unplug the red (right speaker) cord from the motherboard.
    • Unplug the white (left speaker) cord from the motherboard.
  7. Insignia NS-24ER310NA17 Speaker Replacement: 7 단계, 이미지 1/1
    • Start by locating speaker in bottom of back panel.
  8. Insignia NS-24ER310NA17 Speaker Replacement: 8 단계, 이미지 1/1
    • Remove screws on both sides holding the speaker in place.
  9. Insignia NS-24ER310NA17 Speaker Replacement: 9 단계, 이미지 1/1
    • Pull the speaker out of its casing, and repeat for the process for the other speaker.
결론
Hannah Berenjfoorosh
회원 가입일: 01/22/18
533 평판
안내서 3개 작성하였습니다
Cal Poly, Team S16-G2, Banghart Winter 2018 Cal Poly, Team S16-G2, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 26
전체 시간: 1,047
