주요 콘텐츠로 건너뛰기
Insignia NS-B2110 Battery Replacement
필요한 것
  1. Insignia NS-B2110 Battery Replacement, Battery: 1 단계, 이미지 1/2 Insignia NS-B2110 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Battery Replacement: 2 단계, 이미지 1/2 Insignia NS-B2110 Battery Replacement: 2 단계, 이미지 2/2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
결론
Daniel Hodges
회원 가입일: 10/14/13
301 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G31
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 358
