주요 콘텐츠로 건너뛰기
Insignia NS-B2110 Speaker Replacement
필요한 것
  1. Insignia NS-B2110 Speaker Replacement, Battery: 1 단계, 이미지 1/2 Insignia NS-B2110 Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Speaker Replacement: 2 단계, 이미지 1/2 Insignia NS-B2110 Speaker Replacement: 2 단계, 이미지 2/2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Insignia NS-B2110 Speaker Replacement, Bottom Panel: 3 단계, 이미지 1/1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Insignia NS-B2110 Speaker Replacement: 4 단계, 이미지 1/2 Insignia NS-B2110 Speaker Replacement: 4 단계, 이미지 2/2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Insignia NS-B2110 Speaker Replacement: 5 단계, 이미지 1/3 Insignia NS-B2110 Speaker Replacement: 5 단계, 이미지 2/3 Insignia NS-B2110 Speaker Replacement: 5 단계, 이미지 3/3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  6. Insignia NS-B2110 Speaker Replacement, Internal Components: 6 단계, 이미지 1/2 Insignia NS-B2110 Speaker Replacement, Internal Components: 6 단계, 이미지 2/2
    • With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board.
    • More wires! Handle the circuit board carefully and take caution not to stretch the red and white wires connected the board to the other components.
    • Remove the green quarter circle circuit board and place to the side.
  7. Insignia NS-B2110 Speaker Replacement: 7 단계, 이미지 1/1
    • On the brown side of the quarter circle circuit board, remove the two white ribbon cables with pink stripes attached to a plastic connector. To do this, pinch the tabs with your hands while pulling outward on the connector.
  8. Insignia NS-B2110 Speaker Replacement: 8 단계, 이미지 1/1
    • With a Phillips #2 screwdriver, remove four 6mm screws from the rectangular circuit board.
  9. Insignia NS-B2110 Speaker Replacement: 9 단계, 이미지 1/1
    • Remove the two white ribbon cables attached to white plastic connectors from the circuit board by pinching the tabs with your hands and pulling outward on the connector.
  10. Insignia NS-B2110 Speaker Replacement: 10 단계, 이미지 1/1
    • Red and white wires are attached to this board as well. Once again, be careful not to stretch these.
    • Remove the rectangular circuit board and place it to the side.
  11. Insignia NS-B2110 Speaker Replacement: 11 단계, 이미지 1/1
    • With a Phillips #2 screwdriver, remove two 5mm screws from the black plastic frame which previously held up the rectangular circuit board.
    • Remove the black plastic frame.
  12. Insignia NS-B2110 Speaker Replacement: 12 단계, 이미지 1/2 Insignia NS-B2110 Speaker Replacement: 12 단계, 이미지 2/2
    • With a Phillips #1 screwdriver, remove four 3mm screws from the silver metal circuit board.
    • This board has two white ribbons attached to it. Once again, be careful not to stretch these.
    • Remove and place the metal circuit board to the side.
  13. Insignia NS-B2110 Speaker Replacement: 13 단계, 이미지 1/1
    • With a Phillips #2 screwdriver, remove the two 3mm screws from the black plastic tuner frame.
  14. Insignia NS-B2110 Speaker Replacement, Speaker: 14 단계, 이미지 1/3 Insignia NS-B2110 Speaker Replacement, Speaker: 14 단계, 이미지 2/3 Insignia NS-B2110 Speaker Replacement, Speaker: 14 단계, 이미지 3/3
    • Using a Phillips #2 Screwdriver, remove two 5mm screws from the speaker.
    • The edges of the speaker are very thin and sharp and could cut your finger.
    • The speaker will have a light coating of glue to hold it in place. A little force from your fingers will pull it right out. Remove the speaker and set it face-down on the table.
  15. Insignia NS-B2110 Speaker Replacement: 15 단계, 이미지 1/1
    • Remove the solder from the two black and white wires connected to the speaker.
결론
Jacob Phillips
회원 가입일: 10/14/13
313 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G31
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,014
