이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Follow these instructions to remove and replace the transformer in your boombox. This requires some simple soldering, so make sure you have a soldering iron handy and know how to use it. An easy step-by-step guide to soldering can be found here.
필요한 것
Flip the stereo so the CD opening is face down.
With two fingers, pinch the tabs and lift up to open the battery protection cover.
Using a Phillips #2 screwdriver, remove two 4mm screws from the transformer box.
Remove the transformer and set it to the side.
