주요 콘텐츠로 건너뛰기
Insignia NS-B4111 Switchboard Replacement
필요한 것
  1. Insignia NS-B4111 Switchboard Replacement, Battery: 1 단계, 이미지 1/2 Insignia NS-B4111 Switchboard Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Switchboard Replacement: 2 단계, 이미지 1/2 Insignia NS-B4111 Switchboard Replacement: 2 단계, 이미지 2/2
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Switchboard Replacement, Casing: 3 단계, 이미지 1/1
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  4. Insignia NS-B4111 Switchboard Replacement: 4 단계, 이미지 1/2 Insignia NS-B4111 Switchboard Replacement: 4 단계, 이미지 2/2
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  5. Insignia NS-B4111 Switchboard Replacement, Antenna Base: 5 단계, 이미지 1/2 Insignia NS-B4111 Switchboard Replacement, Antenna Base: 5 단계, 이미지 2/2
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
  6. Insignia NS-B4111 Switchboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Unscrew the four 12.5mm screws with the Phillips PH1 Screwdriver.
    • Unscrew the one 10mm long screw with the Phillips PH1 Screwdriver.
  7. Insignia NS-B4111 Switchboard Replacement: 7 단계, 이미지 1/1
    • Orient the device so that the back is facing you.
    • Unplug the six pin male/female header from its socket on the motherboard. The wires on the header are these colors: burgundy, red, orange, yellow, green, and blue.
    • Use a tweezer if you find it hard to pull the header out with your fingers.
    • Gently pull out the ribbon cable from its socket on the motherboard.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the wires the wrong way may short circuit the board.
  8. Insignia NS-B4111 Switchboard Replacement: 8 단계, 이미지 1/1
    • Rotate the device so that the front is facing you.
    • Unplug the four pin header from its socket on the motherboard. The wires on the header are these colors: brown, red, orange, and yellow.
    • Use a tweezer if you find it hard to pull this header out with your fingers.
    • Gently pull out the ribbon cable from its socket.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the base the wrong way may short circuit the board.
  9. Insignia NS-B4111 Switchboard Replacement: 9 단계, 이미지 1/1
    • Pull out the two pin header from its socket on the motherboard. The wires on this header are black and white.
    • Use a tweezer if you find it hard to pull this cable out with your fingers.
  10. Insignia NS-B4111 Switchboard Replacement, Front Panel: 10 단계, 이미지 1/1
    • Remove the four 8.5mm chrome screws from the front panel with the Phillips PH1 screwdriver.
  11. Insignia NS-B4111 Switchboard Replacement: 11 단계, 이미지 1/1
    • Remove the front panel from the top casing.
  12. Insignia NS-B4111 Switchboard Replacement, Switchboard: 12 단계, 이미지 1/1
    • Remove the 10.5 mm screws in the corners with the Phillips PH1 screwdriver.
    • Remove the two 10.5 mm screws near the center of the board with the Phillips PH1 screwdriver.
  13. Insignia NS-B4111 Switchboard Replacement: 13 단계, 이미지 1/1
    • Lift the board to remove it from the front panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sabuk Ketvirtis
회원 가입일: 09/21/16
166 평판
안내서 1개 작성함
UC Davis, Team 1-5, Oliver Fall 2016 UC Davis, Team 1-5, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G5
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 501
