주요 콘텐츠로 건너뛰기
Insignia NS-BCDCAS1 Tape Cassette Player Replacement
필요한 것
  1. Insignia NS-BCDCAS1 Tape Cassette Player Replacement, Outer Panels: 1 단계, 이미지 1/2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement, Outer Panels: 1 단계, 이미지 2/2
    • Turn the boombox around to see the back, and then flip it upside down.
    • Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
    • Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
  2. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 2 단계, 이미지 1/1
    • Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
  3. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 3 단계, 이미지 1/2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 3 단계, 이미지 2/2
    • Remove the two 8mm screws using a 2.5mm flathead driver.
    • The front grey panel will loosen up once the final screw is removed.
  4. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 4 단계, 이미지 1/1
    • Turn the boombox on its back.
    • Release the front panel by pushing down on the latches holding the panels together.
    • There are four silver latches on the top side of the panel and one on the bottom.
    • Do not force the panel comletely off, there are cables attached inside.
  5. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 5 단계, 이미지 1/2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 5 단계, 이미지 2/2
    • Turn the boombox around to view the back and lift the handle up.
    • Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
    • Gently lift the black top but do not pull completely away.
  6. Insignia NS-BCDCAS1 Tape Cassette Player Replacement, Tape Cassette Player: 6 단계, 이미지 1/1
    • Face the bottom of the opened boombox, and detach the front panel from the back in the following order:
  7. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 7 단계, 이미지 1/3 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 7 단계, 이미지 2/3 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 7 단계, 이미지 3/3
    • Unplug the 4 wires (1 red, 2 black, 1 white) from the yellow motherboard on the front panel, by pulling upwards.
    • Pull the black tape attached to the white plug on the yellow motherboard by tugging upwards.
    • Detach the thicker, white and pink cord on the smaller yellow plate on the front panel by pulling away.
  8. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 8 단계, 이미지 1/2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 8 단계, 이미지 2/2
    • Facing the inside of the front panel, on the corners of the grey plate, there are four screws. Unscrew these with a phillips 1.
  9. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 9 단계, 이미지 1/2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 9 단계, 이미지 2/2
    • Face the inside of the front panel. Push the buttons down gently to slide the cassette player unit out.
  10. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: 10 단계, 이미지 1/1
    • On the back of the unit to the right of the motherboard and between the motor and black circle, there is a rubber band that allows the spinning wheels to spin the knobs. Using tweezers, remove the rubber band and replace it.
결론
Erin King
회원 가입일: 09/12/16
215 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team 2-5, Bruce Fall 2016 CSU Fullerton, Team 2-5, Bruce Fall 2016 회원
CSUF-BRUCE-F16S2G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 559
