소개
If your Insignia NS-CLIP02 is not connecting to your Apple device, follow this guide to replace the 30-pin connector. The 30-pin connector transmits audio from the iPhone/iPod to the Insignia NS-CLIP02. A faulty 30-pin will result in distorted or no audio, and no charge coming into the connected device.
Before using this guide, be sure to inspect the spot in which the iPhone/iPod plugs into the device for debris that might be causing the audio issues. If you have another compatible device, be sure to test it on the 30-pin to be sure the iPhone/iPod is not the issue.
Before beginning be sure that the Insignia NS-CLIP02 is not plugged in to any socket, and disconnect any device connected to the 30-pin connector.
필요한 것
