주요 콘텐츠로 건너뛰기
Insignia NS-CLIP02 30-Pin Connector Replacement
필요한 것
  1. Insignia NS-CLIP02 30-Pin Connector Replacement, 30-Pin Connector: 1 단계, 이미지 1/1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 30-Pin Connector Replacement: 2 단계, 이미지 1/1
    • Begin by using the Metal Spudger to peel back the adhesive sticker and locate the screw beneath the sticker.
  3. Insignia NS-CLIP02 30-Pin Connector Replacement: 3 단계, 이미지 1/1
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 30-Pin Connector Replacement: 4 단계, 이미지 1/1
    • Using the Plastic Spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 30-Pin Connector Replacement: 5 단계, 이미지 1/1
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 30-Pin Connector Replacement: 6 단계, 이미지 1/1
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 30-Pin Connector Replacement: 7 단계, 이미지 1/1
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 30-Pin Connector Replacement: 8 단계, 이미지 1/1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 30-Pin Connector Replacement: 9 단계, 이미지 1/1
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 30-Pin Connector Replacement: 10 단계, 이미지 1/1
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 30-Pin Connector Replacement: 11 단계, 이미지 1/1
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 30-Pin Connector Replacement: 12 단계, 이미지 1/1
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 30-Pin Connector Replacement: 13 단계, 이미지 1/1
    • Remove the plug in front of the LCD screen plug.
  14. Insignia NS-CLIP02 30-Pin Connector Replacement: 14 단계, 이미지 1/1
    • Remove the LCD screen plug. Then, follow the previous instructions in reverse, replacing the old motherboard with the new one to fix the 30-Pin Connector.
결론
Erik
회원 가입일: 02/19/15
405 평판
안내서 4개 작성하였습니다
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 8
전체 시간: 214
