주요 콘텐츠로 건너뛰기
Insignia NS-CLIP02 Digital Display Replacement
필요한 것
  1. Insignia NS-CLIP02 Digital Display Replacement, Motherboard: 1 단계, 이미지 1/1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Digital Display Replacement: 2 단계, 이미지 1/2 Insignia NS-CLIP02 Digital Display Replacement: 2 단계, 이미지 2/2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Digital Display Replacement: 3 단계, 이미지 1/2 Insignia NS-CLIP02 Digital Display Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Digital Display Replacement: 4 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Digital Display Replacement: 5 단계, 이미지 1/1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Digital Display Replacement: 6 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Digital Display Replacement: 7 단계, 이미지 1/1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Digital Display Replacement: 8 단계, 이미지 1/3 Insignia NS-CLIP02 Digital Display Replacement: 8 단계, 이미지 2/3 Insignia NS-CLIP02 Digital Display Replacement: 8 단계, 이미지 3/3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Digital Display Replacement, Digital Display: 9 단계, 이미지 1/1
    • Using the Phillips screwdriver, remove the three screws that run along the center of the base.
  10. Insignia NS-CLIP02 Digital Display Replacement: 10 단계, 이미지 1/2 Insignia NS-CLIP02 Digital Display Replacement: 10 단계, 이미지 2/2
    • Carefully remove the base.
  11. Insignia NS-CLIP02 Digital Display Replacement: 11 단계, 이미지 1/2 Insignia NS-CLIP02 Digital Display Replacement: 11 단계, 이미지 2/2
    • Using the metal spudger, gently lift the face plate away from the display.
  12. Insignia NS-CLIP02 Digital Display Replacement: 12 단계, 이미지 1/1
    • Once the face plate is removed, use the Phillips screwdriver to remove the six screws shown here.
  13. Insignia NS-CLIP02 Digital Display Replacement: 13 단계, 이미지 1/2 Insignia NS-CLIP02 Digital Display Replacement: 13 단계, 이미지 2/2
    • Using the metal spudger, lift the speaker grilles from the display.
    • The speaker grilles will hinge on the side closest to the display.
  14. Insignia NS-CLIP02 Digital Display Replacement: 14 단계, 이미지 1/1
    • Using the Phillips screwdriver, remove the four screws shown here.
  15. Insignia NS-CLIP02 Digital Display Replacement: 15 단계, 이미지 1/2 Insignia NS-CLIP02 Digital Display Replacement: 15 단계, 이미지 2/2
    • The two pieces of the display should easily separate.
  16. Insignia NS-CLIP02 Digital Display Replacement: 16 단계, 이미지 1/1
    • Using the Phillips screwdriver, remove the three screws shown here.
  17. Insignia NS-CLIP02 Digital Display Replacement: 17 단계, 이미지 1/3 Insignia NS-CLIP02 Digital Display Replacement: 17 단계, 이미지 2/3 Insignia NS-CLIP02 Digital Display Replacement: 17 단계, 이미지 3/3
    • The digital display should now be easy to remove.
    • Replace with new part.
결론
Aubrey
회원 가입일: 02/24/15
214 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 467
