주요 콘텐츠로 건너뛰기
Insignia NS-CLIP02 Keypad Replacement
필요한 것
  1. Insignia NS-CLIP02 Keypad Replacement, Keypad: 1 단계, 이미지 1개 중 1개
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 Keypad Replacement: 2 단계, 이미지 1개 중 1개
    • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
  3. Insignia NS-CLIP02 Keypad Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 Keypad Replacement: 4 단계, 이미지 1개 중 1개
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 Keypad Replacement: 5 단계, 이미지 1개 중 1개
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 Keypad Replacement: 6 단계, 이미지 1개 중 1개
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 Keypad Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 Keypad Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 Keypad Replacement: 10 단계, 이미지 1개 중 1개
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 Keypad Replacement: 11 단계, 이미지 1개 중 1개
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 Keypad Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 Keypad Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the plug in the front of the lcd screen plug.
  14. Insignia NS-CLIP02 Keypad Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the keypad.
결론
작성자
6다른 기여자 명과 함께
Erik
회원 가입일: 02/19/15
405 평판
안내서 4개를 작성함
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G3
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 228
